PPPoE to Cisco 831 (Ethernet port)
Dec 18th, 2007
Hello folks !!!
I am tring to stabilish a PPPoE session over a ADSL line but i am facing problems with virtual-template interface.
- I has configured PPPoE without NAT.
- My router works like a DHCP server.
- The ethernet 0 (connected to LAN) has a local ip address
- The ethernet 1 ( connected to ISP provider) is configurated to negociate the ip address.
The problem is that I can see different PPP sessions (to different times of show ppp session all). It is cuased because the Virtual-Template interface (created automatically when the Dialer interface is created) is flapping as well.
I need some help to stabilish the session. Is there any other configuration at Virtual-Template interface ?
All is well configured but i don't know if there is any additonal set at virtual-template interface to not flapp the interface
paolo bevilacqua Tue, 12/18/2007 - 10:22
  • Hall of Fame,
    Founding Member
actually for a simple configuration, virtual-template is not necessary.
Just configure a dialer interface and tie it to pppoe-client command.
fabio.nunes Tue, 12/18/2007 - 11:08
Yes I already did it but i am receiving the logs above.
%DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Di1 DDR: Cannot place call, no dialer string set
Above is the currente interface configurations.
interface Ethernet0 (LAN interface)
ip address 10.27.0.1 255.255.255.0
ip virtual-reassembly
ip tcp adjust-mss 1452
no cdp enable
hold-queue 32 in
interface Ethernet1
description $WAN$ (ISP interface)
no ip address
duplex auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
crypto map testmap
crypto ipsec df-bit clear
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer wait-for-line-protocol 3
dialer-group 1
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password 7 123456
How could I do to clear these logs ?
paolo bevilacqua Tue, 12/18/2007 - 11:49
  • Hall of Fame,
    Founding Member
Hi, your dialer might not go up at all, check with debug ppp negotiation and authentication.
fabio.nunes Tue, 12/18/2007 - 13:35
Hi !!!
I can see in the logs that the pppoe session is not been stabilished. There are these logs:
[log cut]
* Vi1 CHAP: I FAILURE id 1 len 43 msg is "Account password must be plain for chap"
[log cut]
* Vi1 PPP: Phase is terminated
* Dialer-6-UNBIND: Interface Vi1 unbound from profile Di1
[log cut]
What does it mean "Account password must be plain for chap" ?
paolo bevilacqua Wed, 12/19/2007 - 02:19
  • Hall of Fame,
    Founding Member
No idea. Try removing CHAP and configure username and password as PAP.
fabio.nunes Wed, 12/19/2007 - 05:23
Hi !!!
Tks for help sir. I will check it with ISP.
The last question:
I would like to clarify the message sent from ISP's AAA server. Do you know the real sense os this message ? "Account password must be plain for CHAP".
I paste the debugging PPP negociation line bellow.
*Mar 2 01:25:11: Vi1 CHAP: I FAILURE id 1 len 43 msg is "Account password must be plain for CHAP"
I apreciate your help for this issue. We don't know if it should be handled by the ISP or by us. Anyway many thanks for the support and attencion.
Brgds.
Fabio Nunes
paolo bevilacqua Wed, 12/19/2007 - 10:14
  • Hall of Fame,
    Founding Member
Really the error message doesn't tell me anything to me and you should clarify with ISP.
You can easily try if you have better luck with PAP as mentioned before. Just configure the usenrmae and password, you can remove altogether the "ppp authentication" statement.
Good luck!
