Broadcom adapters can't connect to 1240AG when using WPA-PSK
Dec 18th, 2007
I'm having a problem with broadcom adapters not being able to connect to our 1240AG access points when using WPA-PSK. Other manufacture's adapters work just fine.
bcolvin Tue, 12/18/2007 - 21:32
this problem could be old drivers or old chipsets that don't support the new encryption methods. have you gotten the latest drivers from the card manufacturer.
Bill
deanhjohnson Mon, 01/07/2008 - 12:03
Some of the devices having the problem are new systems using the latest drivers and/or chipsets. It's all broadcom adapters that seem to have the problem.
rduke Thu, 01/10/2008 - 05:56
I have to agree with the post about drivers regarding the Broadcom cards since most of my Broadcom problems were fixed with the new drivers. What is the version/date of the drivers you are using.
There is one other possible issue. It has been a long time since I saw this problem so I forget the exact details; however, there was a bug in the 1240 AP which caused client connect issues if you had WEP,TKIP, and AES enabled on the AP. Some clients would connect and others would not. I would not have seen this problem since I ususally don't use WEP, but I had to get one WEP device working and hit this bug.
Randy
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
