2801 with 3 ADSL Lines
Answered Question
Dec 18th, 2007
Is there any problem with using a 2801 router with 3 ADSL/POTS interface cards and three lines?
Correct Answer by Paolo Bevilacqua about 9 years 1 month ago
Yes. Just make sure that you have three default routes, static, or learned via DHCP. Then you will also have three NAT statements.
Overall Rating: 5 (1 ratings)
duncan-1gp Tue, 12/18/2007 - 07:09
Cheers, and would it possible to load-balance against the three gateways?
Correct Answer
Paolo Bevilacqua Tue, 12/18/2007 - 07:13
