Multiple paths on non-switchports on 3750
Dec 18th, 2007
I have a 3750 that connects to a 2821 and a 2811. The 2800s connect to our MPLS WAN and use eigrp. How can I get the 3750 to use both paths to the MPLS? It does not seem to use both at the moment. We seem to get congested on the 2821 often while the 2811 seems to have no traffic.
This is our “main” site all our other sites access resources here via T1 connections.
Edison Ortiz Tue, 12/18/2007 - 08:51
You can configure routed ports in the 3750.
interface fx/x
description 2821
no switchport
ip address
interface fx/x
description 2811
no switchport
ip address
then use a dynamic routing protocol or stating routing for balancing both links.
Keep in mind, you are affecting outbound traffic from the 3750 toward the MPLS routers, you aren't affecting inbound traffic on the MPLS routers' WAN links.
That would be a separate configuration and/or requirements.
