ACE sorry server and sticky
Answered Question
Dec 18th, 2007
I have configured 3 different serverfarms with including realservers
2 of them are with websites, the other 1 is with webservices
I also have configured a sorry server farm and the including rserver.
On the sorry rserver i have configured 2 maintenance websites, listening to an unique hostheader.
So for serverfarm A & B i have configured a seperate maintenance website.
Now when i take rservers from serverfarm A or B down, the sorry server will get active for the needed farm.
However i can only reach 1 maintenance website. And even so, an url used to reach farm A gets on maintenance site from B
This is strange behaviour, doesnt a sorryserver just accept requests with the requested hostheader by the client ?
Also, when i put the rservers from A and B back into service i have to do a "clear stick database all" otherwise the sorryserver will remain active.
What is wrong here ?
probe http EHIC-http
description Test op WWW functionaliteit
interval 10
passdetect interval 30
request method get url http://acc.site-B.nl/web/
expect status 200 200
header Host header-value "acc.site-B.nl"
expect regex 1.8.0.2
probe http WWW-http
interval 10
request method get url http://acc.site-A.nl/web/default.aspx
header Host header-value "acc.site-A.nl"
expect regex v1.9.2.327
serverfarm host EHIC-FARM
failaction purge
predictor leastconns slowstart 30
probe EHIC-http
rserver ehic_server01.site-B.nl
inservice
serverfarm host SORRY-FARM
failaction purge
rserver sorrypage.site-C.nl
inservice
serverfarm host WBS-FARM
failaction purge
probe ICMP-PROBE
rserver acc-wbs01v.site-D
inservice
rserver wbs_01.site-D
inservice
rserver wbs_02.site-D
inservice
serverfarm host WWW-FARM
failaction purge
probe WWW-http
rserver acc-www01v.site-A
inservice
rserver acc_server01.site-A
inservice
rserver acc_server02.site-A
inservice
sticky ip-netmask 255.255.255.255 address source EHIC-FARM-STICKY
serverfarm EHIC-FARM backup SORRY-FARM
sticky ip-netmask 255.255.255.255 address source WWW-FARM-STICKY
serverfarm WWW-FARM backup SORRY-FARM
class-map match-any EHIC-VIP
2 match virtual-address 172.30.9.4 tcp eq https
3 match virtual-address 172.30.9.4 tcp eq www
class-map match-any WBS-VIP
6 match virtual-address 172.30.5.4 tcp eq www
7 match virtual-address 172.30.5.4 tcp eq https
class-map match-any WWW-VIP
2 match virtual-address 172.30.6.4 tcp eq www
3 match virtual-address 172.30.6.4 tcp eq https
policy-map type loadbalance first-match EHIC-FARM-STICKY-BALANCE
class class-default
sticky-serverfarm EHIC-FARM-STICKY
policy-map type loadbalance first-match WBS-FARM-BALANCE
class class-default
serverfarm WBS-FARM
policy-map type loadbalance first-match WWW-FARM-STICKY-BALANCE
class class-default
sticky-serverfarm WWW-FARM-STICKY
policy-map multi-match LOADBALANCING-EHIC
class EHIC-VIP
loadbalance vip inservice
loadbalance policy EHIC-FARM-STICKY-BALANCE
loadbalance vip icmp-reply active
appl-parameter http advanced-options EHIC-PARAMETERS
policy-map multi-match LOADBALANCING-WBS
class WBS-VIP
loadbalance policy WBS-FARM-BALANCE
appl-parameter http advanced-options WBS-PARAMETERS
policy-map multi-match LOADBALANCING-WWW
class WWW-VIP
loadbalance policy WWW-FARM-STICKY-BALANCE
appl-parameter http advanced-options WWW-PARAMETERS
Sebastian
Correct Answer by Gilles Dufour about 9 years 1 month ago
Sebastian,
thanks for the new description.
I finally got to understand what you are trying to do.
So, the same sorry server is supposed to check the host header contained in the http request and based on the value decide which page to return.
What you see is that you always get the page for site A.
Did you try to sniff in front of the sorry server to see if the request coming in have the correct hostname ?
I don't think this is an issue with ACE here but more a server config.
ACE does not touch the hostname. So whatever you configured is what will be used.
For the 2nd part, and the need for clearing the sticky database, this does not sound right. I would prefer you to open a service request so that a bug can be opened if necessary by the TAC.
Gilles.
Overall Rating: 5 (2 ratings)
Gilles Dufour Thu, 12/27/2007 - 04:27
Sebastian,
your description is not perfectly clear.
What do you call maintenance website ??
What is the ip address that you use ?
Regarding the sticky behavior, this is not normal. The behavior you descrive is the one you get when you use the option 'sticky' in the definition of the backup serverfarm.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/command/reference/sticky.html#wp1011140
If you are already useing A1(6.3) open a service request to get this investigated.
If not, do an upgrade and see if the problem persist.
Gilles.
sebastianvandijk Tue, 01/08/2008 - 02:49
Hi Gilles,
The maintenance website is a website which contains an "under construction" notice for our customers.
which ip do you mean ?
I have version A1_6_2a, so i'll upgrade to 6.3 first.
Gilles Dufour Tue, 01/08/2008 - 04:34
the name or function of a machine is not useful for troubleshooting.
We prefer to get ip addresses of the device.
So instead of saying the maintenance website did this or that, give us the ip address.
Or use letters like machine A B C D , ....
Just tell us if the device is a client, an rserver or a vserver.
Then give us information like when going from A to B this or that happened.
It's important to know the path of the traffic from source to destination.
Then based on the config, we can tell if something went wrong or not.
Gilles.
sebastianvandijk Tue, 01/08/2008 - 07:09
Hi Gilles,
Here is our full config, i only changed some domain names.
I'll try to describe the problem again ;
We have published a website by vip 172.30.6.4
We have another website published by vip 172.30.9.4
These websites are hosted by realservers configured in 2 serverfarms and can be reached from the internet (secured by an ASA)
For both of these farms i have configured a sorryserver. This sorry server should serve a webpage containing a maintenance message whenever a farm should get down.
The sorry server is configured with 2 websites, each listening to the specific hostheader. This hostheader is the same as configured on the rservers for the specific farm 172.30.6.4 or 172.30.9.4.
So what i am trying to accomplish is that i only need 1 sorryserver to server 2 sorry webpages, ofcourse listening to a hostheader to get 2 different sorrypages to be returned.
Now when i take all realservers for both serverfarms down, except for the sorryserver, i can only reach 1 sorrypage.
For example, site A and B are down, when i try to reach site A i get to the sorrypage of site A. But when i try to reach site B i too get served the sorrypage of site A.
And also when i "inservice" all rservers again i have to do a "clear sticky database", otherwise the sorryserver will remain active.
Now i have upgraded to the last version of the ACE ios, but i still have to test if the same problem persists so i will give feedback on this later.
Sebastian
Correct Answer
Gilles Dufour Wed, 01/09/2008 - 02:20
Sebastian,
Gilles.
sebastianvandijk Fri, 01/18/2008 - 01:17
Hi Gilles,
Problem has been solved for now.
The sticky thing is mentioned in CSCsj59357.
This will be solved in version 2.
The IIS thing was a misconfiguration thing in our config.
Thanks for the help !
Sebastian
