How to configure Etherchannel on Router 3845 L2 Interface?
Answered Question
Dec 18th, 2007
Greetings!!!
I have router with l2 card ,i have planned to configure etherchannel to do a loadbancing .But etherchanel commands are supporting on l2 interface.
Correct Answer by paolo bevilacqua about 9 years 4 months ago
Hi, as neikumar stated before, the HWIC-4ESW doesn't support etherchannel.
Overall Rating: 3 (1 ratings)
paolo bevilacqua Tue, 12/18/2007 - 10:04
  • Hall of Fame,
    Founding Member
Which "l2" card do you have ?
manik.palekar Tue, 12/18/2007 - 20:20
Hi ,
Thanks for support ,I have NM card.Please find the below details.....Thanks
Slot 1:
Mueslix-4T Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision M0
Serial number 34559939 Part number 800-02314-02
FRU Part Number NM-4T=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 54 01 01 02 0F 57 C3 50 09 0A 02 00 00 00 00
0x10: B0 0A 7C 00 06 01 22 00 00 05 FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF
Nagendra Kumar ... Tue, 12/18/2007 - 18:36
  • Cisco Employee,
Hi Manik,
Please be advised that HWIC-ESW card doesnt support port aggregation (ether channel). You may need Etherswitch Network module for port aggregation.
Nagendra
manik.palekar Tue, 12/18/2007 - 20:19
Hello Naikumar ,
Slot 1:
ekhoo Tue, 12/18/2007 - 20:42
Hi Manik,
base on the router output above. You are using 4 port Synchronous Serial Network Module on slot1.
You CANNOT configure "etherchanel" on this Serial network module.
As per Naikumar advised. you need an Etherswitch Network module for port aggregation.
regards,
Sean Khoo
manik.palekar Wed, 12/19/2007 - 08:58
Hello Frd ,
please find the module details ...
WIC Slot 0:
4 Port FE Switch
Base MAC Address : 0016.c8de.8348
MAC Address block size : 4
PCB Serial Number : FOC10040RCV
Hardware Revision : 5.1
Part Number : 73-8474-05
Board Revision : B0
Top Assy. Part Number : 800-24193-01
Deviation Number : 0
Fab Version : 05
CLEI Code : IPUIAE0RAA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-4ESW
Version Identifier : VN/A
Connector Type : 01
EEPROM format version 4
Correct Answer
paolo bevilacqua Wed, 12/19/2007 - 10:12
  • Hall of Fame,
    Founding Member
bvsnarayana03 Wed, 12/19/2007 - 04:12
  • Silver, 250 points or more
have u tried the methods mentioned by me?
