XML Phone Services Recomendations
Dec 18th, 2007
Can someone point me in the right directions for some good resources on creating xml phone services. I know how to add them, but would like some good sources on actually developing them. Thanks in advance.
Erik
Overall Rating: 5 (1 ratings)
davetucker Wed, 12/19/2007 - 08:46
  • Bronze, 100 points or more
Erik,
Depending how confident you are with XML, HTML, ASP and JAVA, http://www.w3schools.com is a good starting place.
Then probably the best resource I have is the Cisco IP Phone Service Development Notes.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_usage_guide_book09186a00807a34b9.html
My advice would be to use the provided tools and analyse the samples so you can understand how they work before you try and tackle your first app.
Good Luck and Happy Programming.
Dave
erikjustinlee Wed, 12/19/2007 - 11:35
I am very comfortable with xml/html, asp and java not so much. I definately appriciate the reply :)
Erik
