Directory Order
Dec 18th, 2007
Is there any way to change the order of directories displayed when pressing the directory button. I want to switch selection #4 and #5.
1. Missed Calls
2. Received Calls
3. Placed Calls
4. Intercom History
5. Corporate Directory
Chris Deren Tue, 12/18/2007 - 10:10
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sorry, with Appliance based CUCM you can not change it nor remove any of these.
HTH,
Chris
fultont Tue, 12/18/2007 - 10:23
Chris,
I would assume then that since I'm running CCM 4.2(3)SR1 a not appliance version that it's possible?
Tim
Chris Deren Tue, 12/18/2007 - 10:25
  • Hall of Fame,
you can locate the ASP/JSP pages and simply modify the order, keep in mind that this is not supported.
Chris
Adam Frankel Tue, 12/18/2007 - 17:36
  • Silver, 250 points or more
Intercom History will be removed in the next official release of the phone firmware for the 41/61.
If you need it removed immediately you can open a TAC Case to request an ES.
