ISDN switch type
Answered Question
Dec 18th, 2007
Our 3845 ISR (12.4(15)T1)only has ISDN switch-type of "primary-ni", and our Unified Manager 6.0 only has NI2 option for ISDN switch-type. Our telco told us their switch is NI2, but our CM Express has been working for months with the gateway set as NI.
Will the ISDN switch type difference (ni/ni2) cause the gateway "endpoint" to not register properly?
Correct Answer by paolo bevilacqua about 9 years 7 months ago
No, it will not.
Beside the fact that NI and NI2 are interoperable, if you use MGCP, which switch type you have configured on the GW, is immaterial, except for SRST.
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 12/18/2007 - 10:09
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
There will be no problems with using Primary-NI, go ahead and select it.
HTH,
Chris
Correct Answer
paolo bevilacqua Tue, 12/18/2007 - 10:11
  • Hall of Fame,
    Founding Member
No, it will not.
