Release 8.0(3) vs 8.0(2)
Dec 18th, 2007
I'm currently running a Pix 525 with a failover. I'm on version 7.2(2) not sure which version to upgrade to? Has anyone had any experiences with 8.0(3) or 8.0(2) good or bad. thanks
acomiskey Tue, 12/18/2007 - 10:45
I believe the release notes say if you're not running SSL vpn then you should stay with 7. I haven't had problems with either on ASA.
oszkari Tue, 12/18/2007 - 16:10
I recently upgraded from 7.2 to 8.0(2) on a ASA 5510 and I had some problems with concurrent ipsec connections. Some of the connections were randomly refused. I had no time to stay on the problem becouse it was a production ASA, so i downgraded to 7.2(3)version and everything worked just fine.
Please come back if you experienced anything interesting after the upgrade.
m-ketchum Tue, 01/22/2008 - 10:46
ASA software is super buggy, so if it's not broke, don't fix it.
We've standardized on version 7.2(3).
Unless you need the features of a newer release, I'd leave it as-is.
