IOS upgrade on Cisco 7206VXR (NPE-G2)
Dec 18th, 2007
Hi All,
Per Cisco recomendation Iam planning to upgrade IOS on 7206VXR (NPE-G2).
From 'sh Ver' :
System image file is "disk2:c7200p-advsecurityk9-mz.124-4.XD3.bin"
Sh bootflash:
show bootvar
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
In the running config , I do not see
anywhere 'boot system disk2:' command. So the rtr picking up the IOS from disk2 without any bootvar..?
Also, when I upload the new IOS to 'disk2' do I have to issue the 'boot system disk2: c7206newios....bin' then same command with old IOS file to boot with new IOS..?
please advise.
Thank you inadvance
Overall Rating: 5 (1 ratings)
Collin Clark Tue, 12/18/2007 - 10:57
The router looks for the first IOS image and boots it if there is not "boot system" statement. If you plan to have two images on the disk you will need the "boot system" statement pointing to the image you want loaded. If there will only be one image you should not need the "boot system" command.
HTH and please rate.
mvsheik123 Tue, 12/18/2007 - 11:23
Thank you for your quick reply. The other question I have on this is...
why the router did not pickup this image while booting-instead picked Disk2 image. Iam not sure, but this is not valid image..?
Please clarify.
Thank you in advance.
Collin Clark Tue, 12/18/2007 - 11:28
This is a boot image, kind of like the rommon image but for 7200's. If you were to delete all the IOS images and you rebooted you go into this bootflash.
KouiQtech Wed, 06/18/2014 - 12:15
Hi Dear
Did you loose you config when you upgrade cisco 7206. I have one here that is rebooting suddenly.
People advise to upgrade the ios. my current ios is c7200p-spservicesk9-mz.124-4.XD10.bin
Please could you advise
Many thanks
