Auto QoS on a 2800 Series Router
Dec 18th, 2007
I want activate Auto QoS on a Cisco 2800 Series Router.
If I change in the Giga-Interface config mode and type "auto qos" than I get the information, that this command does't exist.
What's wrong there. Is there no auto qos on this router?
Yours sincerely
david.2.tucker@... Wed, 12/19/2007 - 03:55
AutoQos is only available on
- ATM PVCs (high and low subinterfaces only)
- Frame Relay DLCIs (point to point Only)
- Serial interface using PPP or HDLC
Bear in mind there are additional prerequisite config requrements for AutoQos.
It would be a good idea check the feature navigator to see if your IOS supports AutoQos Enterprise (12.3T onwards)
Hope this helps.
Dave Tucker
robertdm1973 Fri, 12/21/2007 - 10:02
I have a 2801 and loaded FW ver 12.4(16a) on it and was able to apply AutoQOS on on the FE interface.
Although I haven't tested it yet since my counterpart on the far-end is still setting-up.
Do you this Auto-QOS will not work on the FE port?
nathy1984 Thu, 12/27/2007 - 01:51
I have only Gigabit-Interfaces.
This is the output of the show version. Maybe this will help?
R2#sh version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(6)T, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Feb-06 22:54 by ccai
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
R2 uptime is 15 minutes
System returned to ROM by reload at 12:11:10 UTC Wed Dec 19 2007
System image file is "flash:c2800nm-advipservicesk9-mz.124-6.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2821 (revision 53.51) with 237568K/24576K bytes of memory.
Processor board ID FHK0841F0VU
2 Gigabit Ethernet interfaces
2 Low-speed serial(sync/async) interfaces
1 ISDN Basic Rate interface
1 ATM interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125184K bytes of ATA CompactFlash (Read/Write)
thomuff Thu, 12/27/2007 - 07:06
I don't know if this will help but I am running policy map with class maps applied to the gig interface using service policy command? Is this for voice
nathy1984 Fri, 12/28/2007 - 01:08
It's for voice and for other applications.
I can also run QoS with class maps and policy maps. But I would test QoS.
nathy1984 Tue, 01/22/2008 - 10:51
Does nobody has an idea? What could be the problem?
Best regards
Brandon Buffin Tue, 01/22/2008 - 11:21
Can you post the exact commands you are entering from the time you login to the router up to and including the error message you receive?
nathy1984 Thu, 01/24/2008 - 06:55
I do "configure terminal".
Then I do "interface gigabitEthernet 0/0"
And then I will put the command "auto qos".
But there ist no command "auto"
Do I make something wrong?
Best regards
