12-18-2007 11:41 AM
For some reason I uploaded one image successfully to our Wan Connectivity map. Any other images I try to upload to our other Campus maps I created the map is somewhat distorted, is there a limitation on images you can upload or am I experiencing an idiot alert?
Solved! Go to Solution.
12-18-2007 02:35 PM
This is actually a bug, CSCse24944. The bug will not be fixed due to limitations in the layout engine toolkit we use. The only workaround is not to use a background image.
12-18-2007 02:35 PM
12-18-2007 02:58 PM
Thanks for the explanation. I knew it had to be something preventing me from doing this. I guess we will not be using the background image.
