Incoming sip call are rejected
Dec 18th, 2007
When I receive an INVITE on a SIP trunk, I got a 404 not found.
I got this message in the log:
DOES NOT MATCH top level org domain
If I reset the trunk, everything is ok after. This error occurs after a shutdown of the server (Power outage).
Overall Rating: 1 (1 ratings)
smahbub Wed, 12/26/2007 - 09:06
If you see a incoming SIP call being rejected by sending a 401 Unauthorized reponse to INVITE. then Define a new softswitch trunkgroup with the IP address or domain name used in the FROM field of incoming calls INVITE message.
