ACS administrator account setup
Answered Question
Dec 18th, 2007
I just installed ACS on Windows. I am trying to set up an administrator account. When I set up the account in Administration Control in the browser and click Submit, the browser reports "Error on page" and will not submit. So I am unable to set up an account.
It is installed on Windows 2003 SP1, on top of VMware. Browser is IE6 SP1.
Is there a more compatible browser I should install? Is there another method to set up an admin account?
Correct Answer by andrew.brazier@... about 9 years 7 months ago
Glad that was it, don't forget to rate my post if it was helpful : )
Overall Rating: 5 (1 ratings)
andrew.brazier@... Wed, 12/19/2007 - 05:22
  • Bronze, 100 points or more
IE6 should work fine but have you installed the Java VM on the server? If not go to www.java.com, download and install. The web page should then be OK.
Correct Answer
andrew.brazier@... Wed, 12/19/2007 - 07:17
