inbound and outbound traffic
sujitkr7cisco
can i use two gateway ip for same outbound interface in my cisco ASA5510, if yes ,how?
tstanik
Level 5
Level 5
You can define one default gateway for outbound traffic and a list of static routes to the other gateway. Although this won't load balance across the gateways but will definitely work in a gateway failure case. Also this setting will be applicable to all traffic that matches the static routes.
