T1 Usage
Answered Question
Dec 18th, 2007
I have a Cisco 2811 and we are trying to solve a bandwidth usage problem. Is there a way to determine what host IP is using all the bandwidth on the Serial port?
Correct Answer by Richard Burts about 9 years 5 months ago
Allen
Probably the easiest way to determine that is to configure NetFlow on the router. NetFlow will generate statistics that will identify addresses, protocols, and amount of traffic. It would be especially interesting to configure the option in NetFlow to identify the Top Talkers. This link has information about this:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00805e11ab.html
It seems that it would be just what you need.
Rick
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Burts Tue, 12/18/2007 - 13:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Allen
Rick
Richard Burts Wed, 12/19/2007 - 07:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Allen
I am glad that my suggestion was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read about a question and can know that they will read a response that resolved the question.
I encourage you to continue your participation in the forum.
Rick
