12-18-2007 01:39 PM - edited 03-15-2019 07:51 AM
Is this a compatibility problem to integrate Presence 6.0 with CallManager 5.12?
We are integrating CUPS6.0 with CCM5.12 in a project. After one week efforts, everything is working fine except for the phone presence status on CUPC. The status of contacts logged-in always shows âavailableâ or âidleâ, but never shows âone the phoneâ. In the CUPC preferences configuration, I configured -Show me as âon the phoneâ - Whenever I am on the phone, so it should show âon the phoneâ status if the associated phone is used. The problem looks like the CallManager doesn't send âPublishâ message to Presence.
We also have done the integration of CUPS6.0 and CCM6.0 in our Lab, and there is no this problem.
I am not clear about the configuration from Cisco Docs. Here is the quote from Cisco Unified Presence Settings:
Enable Publish to Cisco Unified Communications Manager check box
Note : This field only displays when you connect to Cisco Unified Communications Manager Release 6.0 or higher.
Cisco Unified Communications Manager SIP Publish Trunk
With the integration of CCM 5.12, I can't see the âEnable Publish to Cisco Unified Communications Managerâ check box and âCisco Unified Communications Manager SIP Publish Trunkâ in the Presence Settings. Does this mean that it should work without these configurations or it is a compatibility problem here? If it should work, what can I do about it?
12-26-2007 10:16 AM
Try this : Go to CCMAdmin -> Device -> Trunk -> SIP trunk -> change destination IP address from DNS name to IP address.
03-06-2008 08:54 AM
Your solution worked for me.
