Connecting Cisco 7940 IP Phone to Asteriks
Dec 18th, 2007
We are testing this and appreciate any information that might be of any help
Overall Rating: 4 (1 ratings)
utawakevou Wed, 12/19/2007 - 14:17
Have got the following from Cisco site:
The converting process states that I need 4 files namely:
Cisco wont allow me to download these files. Is there any other place I can get it. Here is the details of my current 4940 IP phone
MAC Address 001BD52C578B
Host Name SEP001BD52C578B
Phone DN 5299
App Load ID P0030301MFG2
Boot Load ID PC0303010200
Version 3.1(MF.G2)
Thanks for your help
Paolo Bevilacqua Thu, 12/20/2007 - 04:05
I don't think these files are needed for firmware conversion, ignore them or supply empty ones. Later on, you can configure them for further personalization.
utawakevou Thu, 12/20/2007 - 15:39
Manage to change that. On Firmware status it now says
Application Load ID
Boot Load ID
My Asteriks box IP is my number is 4002 with my password 2004
utawakevou Tue, 01/01/2008 - 13:17
How do I reset all the configuration of this phone to the factory default settings ?
Paolo Bevilacqua Wed, 01/02/2008 - 04:01
Power one while pressing #. Release when display "reset sequence dtected". Press 12345689*0#. Press again 2 to confirm network settings erase.
This will erase also the firmware, so you must have DHCP and TFTP server correctly configured to provide firmware again to the phone.
utawakevou Wed, 01/02/2008 - 11:45
Did try that and didnt get that message "reset sequence dtected". Did recycle the power while pressing #. IT go straing into configuring VLAN and then configuring IP then back to the normal phone display
