Display Off Hook Status of Called DN
Dec 18th, 2007
I have a customer that we recently installed CCM 5.1 for...thier old system would notify them that the number being called was on the phone when they called...We have installed AC for some of the users but this appears to be the biggest "issue" thus far. Is there any way to display that the called dn is busy..other than disabling the busy coverage paths and disabling caller waiting.
davetucker Wed, 12/19/2007 - 08:30
If they want this on Internal calls only Communications Manager 5 has some Presence features that may be of use.
You can configure a BLF Speed-Dial button on each phone which will display a presence indication at line level. I believe that this function is also available through the Directory. So providing you dial through the Directory or using a BLF Speed-Dial you should get some indication of whether a user is busy or not before you make the call.
There is more info about presence in the CM 5.X SRND
If they want an external caller to be notified that they are busy, or just want to hear busy tone I can't think of any other option than that which you have already suggested: removing all busy coverage paths etc...
Hope this helps.
joeharb Wed, 12/19/2007 - 08:50
Thanks for the reply...I am familiar with the BLF Speed Dial function..this will not since most of the phones are 7941's this is not an option...we would only be able to give 1 indicator per phone...this would not really help. We have enabled presense on the directory but this doesn't help on transfers or if you dial after you pickup the handset...They are only interested in internal calls...
