Unity Connections 2 forwarding
Dec 18th, 2007
  • Silver, 250 points or more
In the Unity Connection 2, used with the Business Edition Ver 6. How do I make sure that if a number is transfered from someone else (internally) that it goes to the persons mailbox it is transferred to and not the original number called as per default. Is there a global setting I can do to change it. the reason I say this have a CUCM6BE with only 8 DDI and 30 users, all 30 users have VM but as you import the settings from CUM then how do ensure the destination number is the number the VM is left on
Paul
