877 won't complete PPPoA logon
Dec 18th, 2007
Hi all,
I have recently switched out my Cisco 678 here for a Cisco 877 and am trying to get it working on my ADSL link. I have configured the 877 with the PPPoA username and password and static IP, but the PPP light never comes on. (CD light is solid on and DSL line is trained)
The tech at the ISP told me that my router is constantly logging on (successfully, he states) but I never get a PPP light and the link never comes up.
The modem is running Advanced IP Services IOS 12.4(15)T1 and DSL FW 3.0.14.
Here is the sanitized config:
Current configuration : 3982 bytes
version 12.4
no service pad
hostname cnc.chris.877
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
archive
log config
hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode ansi-dmt
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/32
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address 206.63.229.xxx 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxxx
ppp pap sent-username xxxxxxxx password 0 xxxxxxxx
ip route 0.0.0.0 0.0.0.0 206.63.229.xxx
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
webvpn cef
end
Does anyone know what could be causing this?
olighec Tue, 12/18/2007 - 21:12
I did some more research and debugging and it looks like my authentication is failing, but I am assured by the ISP that I am using the correct username and password. In fact, when I plug the 678 in using that User/pass combo, I get a good negotiation and the circuit comes all the way up.
Here is the debug output:
*Dec 19 04:43:57.475: Vi2 PPP: Phase is ESTABLISHING, Passive Open
*Dec 19 04:43:57.475: Vi2 LCP: State is Listen
*Dec 19 04:43:58.299: Vi2 LCP: I CONFREQ [Listen] id 2 len 14
*Dec 19 04:43:58.299: Vi2 LCP: AuthProto PAP (0x0304C023)
*Dec 19 04:43:58.299: Vi2 LCP: MagicNumber 0x2D5A5EC9 (0x05062D5A5EC9)
*Dec 19 04:43:58.299: Vi2 PPP: No remote authentication for call-out
*Dec 19 04:43:58.299: Vi2 LCP: O CONFREQ [Listen] id 204 len 10
*Dec 19 04:43:58.299: Vi2 LCP: MagicNumber 0x1E65F76B (0x05061E65F76B)
*Dec 19 04:43:58.303: Vi2 LCP: O CONFACK [Listen] id 2 len 14
*Dec 19 04:43:58.303: Vi2 LCP: AuthProto PAP (0x0304C023)
*Dec 19 04:43:58.303: Vi2 LCP: MagicNumber 0x2D5A5EC9 (0x05062D5A5EC9)
*Dec 19 04:43:58.343: Vi2 LCP: I CONFACK [ACKsent] id 204 len 10
*Dec 19 04:43:58.343: Vi2 LCP: MagicNumber 0x1E65F76B (0x05061E65F76B)
*Dec 19 04:43:58.343: Vi2 LCP: State is Open
*Dec 19 04:43:58.343: Vi2 PPP: Phase is AUTHENTICATING, by the peer
*Dec 19 04:43:58.343: Vi2 PAP: Using hostname from interface PAP
*Dec 19 04:43:58.343: Vi2 PAP: Using password from interface PAP
*Dec 19 04:43:58.343: Vi2 PAP: O AUTH-REQ id 93 len 21 from "xxxxxxxx"
*Dec 19 04:43:58.395: Vi2 PAP: I AUTH-NAK id 93 len 15 msg is "Username: "
*Dec 19 04:43:58.395: Vi2 LCP: I TERMREQ [Open] id 3 len 4
*Dec 19 04:43:58.395: Vi2 LCP: O TERMACK [Open] id 3 len 4
*Dec 19 04:43:58.395: Vi2 PPP: Sending Acct Event[Down] id[A62]
*Dec 19 04:43:58.395: Vi2 PPP: Phase is TERMINATING
*Dec 19 04:43:59.415: Vi2 LCP: I CONFREQ [TERMsent] id 1 len 14
*Dec 19 04:43:59.415: Vi2 LCP: AuthProto PAP (0x0304C023)
*Dec 19 04:43:59.419: Vi2 LCP: MagicNumber 0x2D5A6AEB (0x05062D5A6AEB)
*Dec 19 04:43:59.419: Vi2 LCP: Dropping packet, state is TERMsent
*Dec 19 04:44:00.387: Vi2 LCP: Timeout: State TERMsent
*Dec 19 04:44:00.387: Vi2 LCP: State is Closed
*Dec 19 04:44:00.387: Vi2 PPP: Phase is DOWN
It appears that when I send my username, the device on the other side prompts me "Username: ", suggesting that I have given an incorrect logon name.
Has anyone seen this before? I am trying to get details about the device on the other side of the link, but it's difficult to get ISP techs to tell me exactly what hardware they have.
Any help anyone can offer would be great.
I've already tried switching between dsl operating-mode auto and ansi-dmt with no change. I also have removed the CHAP authentication from the Dialer0 interface since I verified that the ISP was using PAP.
Chris
jamesgonzo Thu, 12/20/2007 - 04:54
Looks ok to me, the only difference I have is:
cdp enable
pvc 0/38
Here:
interface ATM0
no ip address
no ip unreachables
no ip mroute-cache
atm vc-per-vp 64
cdp enable
pvc 0/38
