Is Cisco 2821 Router a Voice gateway?
Answered Question
Dec 19th, 2007
hi all,
this is my first post in the forum,
i want to know if Cisco 2821 router a voice gateway also? or should i have to add some module or wic? A PRI will be terminated at 2821.
please advise
thanks
Correct Answer by paolo bevilacqua about 9 years 4 months ago
Yes.
Remember you also need PVDM2 that is the required DSP resources, to use router for VoIP. Do "show diag" to know if you have it and what "size" it is.
Overall Rating: 3 (3 ratings)
zeeshan.a Tue, 12/25/2007 - 23:14
thnx,
i have 2811 with E1 card for PRI, so i can directly connect IP PBX to this Router for VoIP.
Correct Answer
paolo bevilacqua Wed, 12/26/2007 - 03:36
  • Hall of Fame,
    Founding Member
yxsjwsb Wed, 12/26/2007 - 22:32
And once you get the router set up, go get the E1 Pri debug demo from pippinsoftware.com , it's handy for troubleshooting.
zeeshan.a Tue, 01/01/2008 - 03:31
one more thing with PVMD2, does 2821 support SIP?
Correct Answer
paolo bevilacqua Tue, 01/01/2008 - 03:35
  • Hall of Fame,
    Founding Member
Yes.
