ip phone directory
Dec 19th, 2007
i want a directory's it currently shows the following:
1: Missed calls
2: Received calls
3: Placed calls
4: Personal Directories (This Requires a login)
5: Corporate Directories
Does anyone know how this can be done?
Thanks!
Mark Pareja Wed, 01/02/2008 - 13:49
I believe what your asking is to re-order the Directories List, and to answer your question the first three entries that appear in the Directory page of the phone cannot be augmented, thare are programed as part of the Phones Firmware. the Subsequent two can be modified however it requires modification of ASP or JSP(UCM5-up) web pages.
http://cisco.com/en/US/partner/products/sw/voicesw/ps556/products_programming_usage_guide_book09186a00807a34b9.html
This is a link to the IP Phone Services SDK that should give you a better understanding of the task your about to take on.
You will need a basic understanding of HTML and XML.
