Problems monitoring phones with 2 lines, using jtapi user
Dec 19th, 2007
Hi all,
I'm using a third party application in order to monitor phones state via jtapi user created ad hoc.
I have problems monitoring phones with two lines, that is starting the server which run the application I need to delete the second line and create it again to monitor the device.
Does anyone have an idea of which could be the problem?
mmaddalena Thu, 01/03/2008 - 05:09
thanks for your advice, it's very important.
The problem is taht this bug is not visible in the bulg toolkit, can you post the details?
Thanks!
Best Regards
Michele
