4.2 SR3 update problems
Dec 19th, 2007
"unable to open the script file"
I get this error when trying to update 4.2(1) to SR3. I am running 4.4sr10 for the OS which is the minimum spec for SR3 but get theis error when I try to run the SR3 update. CSA, anti V are disabled. This error happens after I click the sr3.exe, I select yes to install and it exracts the files.
Any ideas
Overall Rating: 5 (1 ratings)
n.lichatz Wed, 12/19/2007 - 04:13
My update is working now, The only thing I did was uninstall CSA and reboot a bunch of times.. Ive never seen this error before, but its good now...
rob.huffman Wed, 12/19/2007 - 06:14
Hi Nick,
Thanks for posting back with this valuable info! 5 points from this end for your great work :)
Take care,
