Tool to identify use of Unity accounts?
Dec 19th, 2007
Using unity 4.2
Is it possible to identify mailbox use en-masse? fairly sure many mailboxes are dormant but need to verify. tks
Overall Rating: 5 (1 ratings)
rob.huffman Wed, 12/19/2007 - 06:07
Hi Tony,
I think a great place to start would be to use this excellent Unity Tool;
Cisco Unity Tools - Subscriber Information Dump (this can create a .csv file that contains much information including the following)
Date of subscriber creation. The date the subscriber was added to the Unity system.
Time of Last Call. Indicates the date and time the user called in to check messages last. This can be handy for finding out which boxes have not been access at all or which ones have not been accessed in a long time. This value is in GMT and not your local time, keep that in mind.
http://www.ciscounitytools.com/APP_subr_info_dump_3x.htm
Hope this helps!
Rob
