CUCM 6 hardware
Dec 19th, 2007
To install CUCM 6.0, is any server which meets minimum requirements ( 2GB RAM for example) sufficient or do we still need to go for Cisco approved servers only like in 4x versions?
Overall Rating: 5 (2 ratings)
Rob Huffman Wed, 12/19/2007 - 06:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Abhijit,
How's things? It is Highly recommended to use only Cisco supported servers for CCM 6.x production builds. Here is an excellent list;
This doc shows all the supported models for the different CCM Versions ;
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
UCBNOCWAN Wed, 12/19/2007 - 09:49
Hi Rob,
Will definitely check it out on Monday, currently I am on leave..Thanks as usual for your support. Wish you a very merry Christmas in advance...
Abhijit.
Rajesh Revuru Thu, 12/20/2007 - 09:33
  • Silver, 250 points or more
Rob:
Is there a similar matrix which outlines other applications like Unity/IPCC/MPE.
I searched a lot on cisco.com and couldnt find it.
This matrix is really helpful to determine hardware dependency
UCBNOCWAN Wed, 12/19/2007 - 09:50
Steffen,
Thanks a lot for your support. Wish you a very merry Christmas in advance.
