Link E1 between Cisco 7206 down
wilson2007
I have a link E1 between routers Cisco 7206, on the one side the Cisco 7206 has PA-MC-8E1-UNBAL card with BNC conectors and on the other one PA-MC-8E1+ card with RJ48 conectors. This E1 is part of a multilink ppp.
The configurations and results are:
interface Serial2/1
description Enl_Uio_Gye4
no ip address
ip accounting output-packets
encapsulation ppp
no ip mroute-cache
timeslot 1-31
serial restart_delay 0
fair-queue
ppp multilink
ppp multilink group 10
7206#show interface serial 2/1
Serial2/1 is up, line protocol is down
Hardware is 4ME1-UNBAL
Description: Enl_Uio_Gye4
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 128/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Listen, multilink Closed
Closed: CDPCP, crc 16, loopback not set
Restart-Delay is 0 secs
Last input 14:31:57, output 00:00:22, output hang never
Last clearing of "show interface" counters 3w4d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1096
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
343794192 packets input, 2549208985 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 4 giants, 0 throttles
213263195 input errors, 62610010 CRC, 0 frame, 1000 overrun, 0 ignored, 150
652185 abort
345064202 packets output, 2914045575 bytes, 0 underruns
0 output errors, 0 collisions, 2359 interface resets
2533 carrier transitions
DCD up, BER inactive, NELR inactive, FELR inactive
controller E1 2/1
framing NO-CRC4
channel-group 0 timeslots 1-31
description Uio_Gye4
interface Serial2/1:0
bandwidth 1544
no ip address
encapsulation ppp
ppp multilink
URD_7206#show interface serial2/1:0
Serial2/1:0 is up, line protocol is down
Hardware is PA-MC-8TE1 Plus
Closed: BACP, crc 16, loopback not set
Last input 17:39:06, output 00:00:09, output hang never
Last clearing of "show interface" counters 1d09h
Conversations 0/1/16 (active/max active/max total)
296 packets input, 7548 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 44 giants, 0 throttles
537995927 input errors, 152019559 CRC, 0 frame, 49 overrun, 0 ignored, 3859
73576 abort
13669 packets output, 502349 bytes, 0 underruns
22 carrier transitions no alarm present
Timeslot(s) Used:1-31, subrate: 64Kb/s, transmit delay is 0 flags
How can I do to work this E1. Pls your help.
Wilson
Richard Burts
Wilson
Would I be correct in assuming that this link used to work and then stopped working (rather than being a new install which is not working and has never worked)?
It looks to me like the E1 has a problem in the network. I would check with the provider and ask them to check the link.
For testing purposes you could take the E1 out of the multilink bundle and work with it as an isolated link. But I do not believe that the problem has anything to do with multilink.
Rick
Rick
Thanks Rick.
This E1 is new and has never worked. I have others E1s but between PA-MC-8E1+ ports, these are working.
Also, I tested this link take out of the multilink but I get the same result.
The E1 provider tells me that all is ok.
Wilson
Wilson
With the number of packets sent and received I thought it might be an existing link:
652185 abort
If you look at the number of errors there is certainly something wrong. I am not clear whether the different card types is a problem. Perhaps someone with more experience can help with this.
Can you post the configuration of the controllers from both ends?
Rick
Rick
