EAP-TLS or PEAP authentication failed during SSL handshake to the ACS serve
Dec 19th, 2007
We are running the LWAPP (2006 wlc's and 1242 AP's) and using the ACS 4.0 for authentication. Our users are
experiencing an issue, where they are successfully authenticated the first time, however as the number of them is increasing, they're starting to drop the connections and being prompted to re-authenticate. At this point, they are not being able to authenticate again.
We're using PEAP for the authentication and Win XP SP2 clients as the supplicants. The error message that we are seeing on the ACS for that controller is "EAP-TLS or PEAP authentication failed during SSL handshake to the ACS server"...Not sure if this error msg is relevant since we have other WLC's that are working OK and still generating the same error msg on the ACS...
Thanks..
Scott Fella Thu, 12/27/2007 - 18:15
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Here are some configs you can try:
config advanced eap identity-request-timeout 120
config advanced eap identity-request-retries 20
config advanced eap request-timeout 120
config advanced eap request-retries 20
save config
axfalk Fri, 12/28/2007 - 07:33
Thanks...I have tried these tweakings and, unfortunately, to no avail...Any other suggestions? Thnx again...
Scott Fella Fri, 12/28/2007 - 08:35
  • Hall of Fame,
    2017 Wireless
What logs are you seeing on the ACS and in the WLC2006?
Trending Topics - Security & Network
