upgrade CUCM 5.1.2 to CUCM 6.0(1)
Dec 19th, 2007
Anyone seen a document for this? Is it really as simple as it sounds for using the
cisco-ipt-k9-patch6.0.1.2000-3.tar.gz.sgn
file, let it load, then reboot and cross your fingers?
Thanks!
Overall Rating: 4 (1 ratings)
Chris Deren Wed, 12/19/2007 - 15:52
You got it, the upgrade procedure is just like any other patch upgrade from 5.X.
HTH,
Chris
Tommer Catlin Wed, 12/19/2007 - 16:11
Thanks much. Have you been using any other builds other than the one I listed?
