Configure ILO
Dec 19th, 2007
Can anyone point me in the right direction as to how to configure ILO (integrated lights out) on an MCS/HP server? I've been told that you can configure ILO through via a browser but cannot find any documentation on it. Any assistance would be appreciated.
Glenn
Chris Deren Wed, 12/19/2007 - 15:50
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
While the server is rebooting there is an option to press F9 or somthing like that to get into iLO configuration, you will need to configure it there, assign IP address, DNS, user name/password, etc.
After that you can simply go to http:// and access it there, you will be prompted to enter license key there as well.
Make sure you plug network cable to the iLo network adapter and put it in the correct VLAN, etc.
HTH,
Chris
