How to block MSN file transfer only
Dec 19th, 2007
I have an ASA firewall and I want to block the users to transfer files in the MSN instant messenger. I know there is a feature in Application Policy that should take care of it but it's not workint, I've set the IM inspection and set the File-transfer to reset connection but the users are still able to transfer files through it.
Any idea?
JORGE RODRIGUEZ Fri, 12/21/2007 - 05:07
Correct, I was wrong I tested it as well and did not work.. I guess this must be blocked through app layer protocol inspection rules, let me take a look and possibly lab this out.
guibarati Thu, 12/20/2007 - 03:12
Sure, here it is:
class-map global-class
match default-inspection-traffic
class-map type inspect im match-all IM_MSN
match protocol msn-im yahoo-im
match service file-transfer
class-map mss_ajust
match access-list mss
class-map inside-class
match access-list inside_mpc
class-map IPS_map
match access-list IPS
class-map global-class1
match access-list global_mpc
policy-map type inspect im IM_Map
match not service chat
drop-connection log
policy-map IPS_policy
class IPS_map
ips inline fail-open
policy-map mss-http
class mss_ajust
set connection advanced-options mss-map
inspect http
policy-map global-policy
class global-class
inspect im IM_Map
inspect ftp
inspect icmp
class global-class1
inspect im IM_Map
policy-map inside-policy
description Block msn
class inside-class
inspect im IM_Map
service-policy global-policy global
service-policy mss-http interface outside
service-policy inside-policy interface inside
I have tried to drop the traffic that maches:
not chat
file transfer
none has worked.
