IOS upgradtion
Dec 19th, 2007
Iam holding a 2950 switch with the older version of IOS,i need to upgrade to latest verson and can anyone help to give step by step procedure to implement the same
Danilo Dy Wed, 12/19/2007 - 21:20
Hi Vinoth,
First, difference between update and upgrade. Update means same feature but newer version,. i.e. IP SERVICES 12.2.3 to IP SERVICES 12.2.40 - this update can be done if you have hardware/software maintenance, no extra charge. Upgrade means upgrading to new feature, i.e. from IP SERVICES to ADV IP SERVICES - this will cost you.
Second, you need to know the following (can be taken by "show version" command);
1. Exact model of your switch
2. RAM and FLASH size of your switch
3. Current IOS Feature
Third, contact your vendor to provide you the latest IOS image for your switch. Including the MD5 so that you can check the image if its in good condition
Fourth, either your vendor will perform the update for you or you can do it yourself.
1. You need a PC with Terminal (i.e. Tera Term Pro) and TFTP (i.e. 3COMDaemon)
2. A roll-over cable for Terminal and a straight cable for file transfer
3. Follow the steps in this link
Save and backup the current configuration before performing the upgrade.
