Unable to view 2800 series router in Ciscoview
Dec 19th, 2007
Hi All,
In the last year I've worked for two companies, each running Ciscoworks LMS2.6 and in each company I've experienced the same problem. When trying to view a 2800 series router in ciscoview the message below appears.
Message
Can't find applicable device package for x.x.x.253.
Am I right in thinking that cisco have not provided a device package for this router. If anyone knows if there is a device package for this router I'd be greatful if you'd let me know.
Neil
Joe Clarke Wed, 12/19/2007 - 22:45
There is a device package for 2800 series routers. The package is called Rtr2800. Of course, without knowing the exact sysObjectID of this router, I cannot say if the device is supported by the current package.
You can find CiscoView packages by going to Common Services > Software Center > Device Update and performing a download and installation of new packages directly from Cisco.com. Alternatively, you can go to http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi and find packages that way.
neil_titchener Thu, 12/20/2007 - 14:54
Thanks for that. I've tried many times to do a device update but it's never downloaded the 2800 router package for ciscoview. I've manually downloaded it and will install it once back from xmas holidays.
Thanks for your help
