Still One way audio
jkofosu
Hello all,
I have been working on a one way audio issue for sometime now and the problems still persist. What I have discovered is that, when there is a voice call across the link, all ping tests are dropped. I have applied QoS on the link but the same problem persists. The best ping result is 1700ms when there is a single call. I have used several codecs to change the compression rate but the same problem."ONE WAY AUDIO". Routing is fine.
attached is the configs. Please let me know what you think.
8 Replies 8
davetucker
Try adding the following to the config
"voice-class codec 10" command under each voip dial-peer.
"h323-gateway voip bind srcaddr x.x.x.x" on each Ethernet interface where x.x.x.x is the Voice vLAN IP Address.
Let me know if this helps.
Dave
Hello Dave,
Thanks for the post. I have tried the voice-class codec 10 on all the dial-peers but the issue is the same. We are using FXS connected directly to the back of the router so there are no vlans configured. Hope to hear soon.
interface FastEthernet0/0
ip address 10.5.0.254 255.255.255.0 secondary
ip address 172.21.57.253 255.255.255.0 secondary
ip address 10.254.254.10 255.255.255.0
h323-gateway voip bind srcaddr 10.254.254.10
service-policy output VOICE-POLICY
duplex auto
speed auto
Try adding the H323 binding command to the IP address that is being targetted by the dial-peers. If this doesn't work please let me know and I'll need the results of some debugs...
Dave
Hello Dave,
Thanks again. I have done this but the problem persists.
Rgds.
Can you get me the debug outputs of the 2 routers on a call from A to B.
deb voip dialpeer
deb voip rtp
Also what speed is the link between the 2 routers and what technology? Frame, ATM, Ethernet etc...
You should also consider using Class Based Packet Marking in your QoS Policy.
policy-map VOICE-POLICY
class voice-traffic
priority 160
set ip dscp ef
class voice-signal
bandwidth 16
set ip dscp cs3
class class-default
set ip dscp 0
fair-queue
Although the current policy allows 160 of priority bandwidth in times of congestion, the packet is not marked with any dscp value.
vinay_verma80
use the policy map
interface Loopback323
description ---
ip address " Ip of loopback address"
h323-gateway voip bind srcaddr " ip address of loopback "
use policy map
class voice-traffic
priority 160<<<<<<<<< depending who many port around 25k to 27k per FXS port
( for marking the RT and signaling both As ef use " set-dscp-transmit ef")
class class-default
fair-queue
random drop
class-map match-all voice-traffic
match Match access-group name RT
Extended IP access list DSCP-OUT-RT
10 permit ip host "ip add of loopback" any
20 deny ip any any
Also what is ur interface speed (configured on router ) and the actually speed , if if is leas than 764k u also have to use fragmentation
also remember QOS is end to end
after these policy see if ur packet are getting marked or not
canowlin
try something simple like this
voice call send-alert
voice rtp send-recv
voice service voip
h323
no h225 timeout keepalive
modem passthrough nse codec g711ulaw
voice class h323 1
h225 timeout tcp establish 3
description connection Voice Vlan
ip address 10.15.53.1 255.255.255.0
duplex full
speed 100
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.15.53.1
your pings could be a circuit issue.... which would probably cause quality issues. did you look at your interfaces?
