question about port upgrade on CRA 3.x
Dec 20th, 2007
I have CRA 3.x (IPCC Express). CCM and CRA are installed on the same server. Accordingly, for this configuration I can use only 10 ports. As I known, it is possible to increase quantity of ports up to 150. But for this purpose it is necessary to install CRA on separate server.
Unfortunately, official information on this upgrade, I have not found.
Can you give me reference to the document in which this upgrade is described.
In advance thanks,
Best regards,
alex_hannah Thu, 12/20/2007 - 07:05
Seperate server my friend. You would MELT your call manager if you had it co-res with IPCCX and 150 ports up at one time...
Also look at an upgrade while your at it, atleast to 4.x
grisadovoy Mon, 12/24/2007 - 00:11
Thanks for your answer!
Can you give me reference about port upgrade?
Also, can you say me, what I should do, for increase my 10 port.
Best regards
