UIpgrade path options for 5.1.x
Dec 20th, 2007
  • Silver, 250 points or more
I`ve seen the upgrade path doc showing the path for 3.x, 4.x , 5.x upgrading to 6.x. It shows you can upgrade from 5.1.x to 6.x but I`m also aware that you can not go from 5.1.3 to 6.x . We are currently running 5.12.a and have to upgrade to either 5.1.2b or 5.1.3. but my concern is if we chose 5.1.2b can we still go to 6.x ? or is it just 5.1.1.3 which can not go 6.x
Rob Huffman Thu, 12/20/2007 - 06:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Wayne,
This restriction does not apply to CCM 5.1.2b (as it does to CCM 5.1.3) :)
Release Notes for Cisco Unified CallManager Release 5.1(2b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/5_1_2/512bcmrn_1.html
Here is the CCM 5.1.3 note;
Do Not Upgrade from Cisco Unified CallManager 5.1(3) to Cisco Unified Communications Manager 6.x
It is not possible to successfully upgrade from Cisco Unified CallManager Release 5.1(3) to Cisco Unified Communications Manager Release 6.x.
Release Notes for Cisco Unified CallManager Release 5.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/5_1_3/513cmrn.html#wp188112
Hope this helps and Happy Holidays!
Rob
