12-20-2007 05:28 AM - edited 07-03-2021 03:07 PM
I am just having a horrible time implementing Migration mode. I'm sure it's me. 8-)
I am running an autonomous 1240AG. It is currently set up as static WEP/PSK.
I would like to "add" WPA/PSK to the existing SSID.
Is this possible? or does migration mode not work with WPA/PSK?
I have studied all the docs I can find but the best I have been able to do allowed the WPA/PSK users to connect but the WEP/PSK users were locked out.
Any advice, sample configs, prozac, is greatly appreciated.
Mike
12-20-2007 10:30 AM
Hi Mike,
I have never used this but I hate to see you have to pull out the Prozac :) The example certainly seems to support WPA/PSK.
Configuring WPA Migration Mode
WPA migration mode allows these client device types to associate to the access point using the same SSID:
â¢WPA clients capable of TKIP and authenticated key management
â¢802.1X-2001 clients (such as legacy LEAP clients and clients using TLS) capable of authenticated key management but not TKIP
â¢Static-WEP clients not capable of TKIP or authenticated key management
If all three client types associate using the same SSID, the multicast cipher suite for the SSID must be WEP. If only the first two types of clients use the same SSID the multicast key can be dynamic, but if the static-WEP clients use the SSID, the key must be static. The access point can switch automatically between a static and a dynamic group key to accommodate associated client devices. To support all three types of clients on the same SSID, you must configure the static key in key slots 2 or 3.
To set up an SSID for WPA migration mode, configure these settings:
â¢WPA optional
â¢A cipher suite containing TKIP and 40-bit or 128-bit WEP
â¢A static WEP key in key slot 2 or 3
This example sets the SSID migrate for WPA migration mode:
ap1200# configure terminal
ap1200(config)# interface dot11radio 0
ap1200(config-if)# encryption mode cipher tkip wep128
ap1200(config-if)# encryption key 3 size 128 12345678901234567890123456 transmit-key
ap1200(config-if)# ssid migrate
ap1200(config-ssid)# authentication open
ap1200(config-ssid)# authentication network-eap adam
ap1200(config-ssid)# authentication key-management wpa optional
ap1200(config-ssid)# wpa-psk ascii batmobile65
ap1200(config-ssid)# exit
From Darren @ Cisco Systems;
From Ben @ Cisco Systems;
Hope this helps!
Rob
12-21-2007 12:59 PM
Rob:
Thanks for the reply.
I am at a disadvantage as I am not all that familiar with IOS. I usually use the web server for configuration. 8-(
Some questions:
In your example, is Key 3 my static WEP key? (currently Key #1)
Does the "authentication open" line affect my WEP/PSK users? Currently, the config file has "shared" and the users are all wep/psk.
Can you explain the "authentication network-eap adam" line? We are not using EAP, just "personal" mode.
If it helps, attached is my current wep/psk working config file with the keys/passwords alterated.
Mike
12-23-2007 07:51 AM
Hi Mike,
As I said, I have never tried this before and sadly can't test this for you as we run Lightweight now. It seems from your first post that you were very close to having this working :) It would be most helpful to see what the "migration mode" config looked like. To me, it seems like this line may have been missing;
AP SSID is also set for "Authenticated key management- WPA- Optional". As noted by Darren from Cisco.
Let us know,
Rob
12-23-2007 05:43 PM
Thanks, Rob. I appreciate your input!
Happy Holidays,
Mike
01-09-2008 02:33 PM
I am currently having the same issue as you did above. When configuring for transition (TKIP + WEP 128 bit) mode my WPA client can connect but my original WEP client cannot. Was a resolution ever found?
