12-20-2007 05:37 AM - edited 03-03-2019 08:00 PM
Hi All,
we are registering a lot of output drops on ATM E3 interface, the same number of drops is identified as packets late drop. There are no any drops on any subinterface on atm vc level. As you can see the volume of output traffic is low. It is ATM PA-E3 module in VIP4-50 on 7513 series router. Do you have any idea, why the amout of output drops is up to 10% of total amount of output packets, what's (and why) it's happening?
R1#sh int atm 8/1/0
ATM8/1/0 is up, line protocol is up
Hardware is cyBus ENHANCED ATM PA
Description: To_ATM_switch
MTU 4470 bytes, sub MTU 4470, BW 33920 Kbit, DLY 200 usec,
reliability 255/255, txload 2/255, rxload 53/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
4095 maximum active VCs, 15 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:42:45
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 289839
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
30 second input rate 7133000 bits/sec, 700 packets/sec
30 second output rate 378000 bits/sec, 531 packets/sec
3747175 packets input, 3759549860 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3050881 packets output, 624861789 bytes, 0 underruns
289839 packets late drop, 28441753 bytes late drop
R1#sh atm vc int atm 8/1/0 de | i Drop
InPktDrops: 0, OutPktDrops: 0
Thank You for any comments
JM.,
12-21-2007 06:06 AM
Report this to your line service provider.
Check this link http://www.cisco.com/warp/public/121/atmdrops2.html
Dandy
