m.volodko Thu, 12/20/2007 - 06:45
I believe that you can use IAS service from windows server for this. ASA supports radius protocol, well it will looks like ASA->radius->AD.
majdalani Fri, 12/21/2007 - 04:45
Hi Thanks for your reply.
one question, can i install IAS on my DC ??
so that RADIUS Server will be the same as DC Server?
IF IAS is installed on a DC, will radius be able to lookup users from the AD ?
m.volodko Fri, 12/21/2007 - 05:45
Yes.
Yes.
Yes.
It's definitely works, I did the same when implement dot1x.
majdalani Fri, 12/21/2007 - 06:16
Do u have any article on how to configure ASA 5500 to use RADIUS in its OUTBOUND rules authentication ?
m.volodko Fri, 12/21/2007 - 06:22
If you are using radius behind outside interface you have to specify it like:
ciscoasa(config)# aaa-server RADserver (outside) host 10.10.10.10
majdalani Fri, 12/21/2007 - 06:30
I want to authenticate my Internal Users, so that based on the authentication, if they go thru Rule # 1 or Rule # 2 in CISCO ASA.
In this stage, i am not intending to authenticate VPN ( Remote Users ) .
I need to authenticate Internal Users.
lets say i want to create the following rules:
rule 1 : allow> protocols> from internal > to external > groupA
rule 2 : allow> protocols> from internal > to external > groupB
is this possible ?
majdalani Fri, 12/21/2007 - 09:27
mmm, i would prefer if there is an article that illustrate how to do it with the GUI ( PDM ) , as i am guy who is used to work with GUI stuff :)
Thanks will check it.
