Sup720 memory upgrade
Dec 20th, 2007
when upgrading the memory in the Sup720 router proccessor
this link states that I should insert 2 dimm modules
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_15538.html#wp33337
but the mem upgrade MEM-MSFC3-1GB
is just one dimm
what is the correct way to upgrade the memory ?
Danilo Dy Thu, 12/20/2007 - 06:37
  • Blue, 1500 points or more
I think one of them is for switch processor and the other is for route processor as mentioned in this link http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080159856.html
• WS-SUP720 supports 512MB of DRAM for the route processor and 512 MB for the switch processor
• WS-SUP720-3B supports 512MB of DRAM for the route processor and 512 MB for the switch processor, upgradeable to 1GB
• WS-SUP720-3BXL supports 1GB DRAM for route the processor and 1GB DRAM for the switch processor
Therefore you need two 1GB DRAM if your model is WS-SUP720-3BXL
Dandy
