NAC and Novell LDAP authentication
Dec 20th, 2007
We are in the process of configuring NAC and having trouble with the LDAP authentication to our Novell network.
Using:
Novell Server 6.5
CAM ver 4.1.2.1
Under User Management --> Auth Servers we have set up our LDAP provider and tried every combination under the sun for the Search Full DN, Search Base Context, and Search Filter fields but can't find the correct combination to make authentication work correctly.
Can anyone help us with the correct syntax?
Thanks, Ben
bhhouston Thu, 01/03/2008 - 05:15
Thanks for the response. We gave this a try and still had no luck so we've decided to open a TAC case.
