Command to verify High Speed Fan in 6500 Chassis
Dec 20th, 2007
I need to upgrade 20+ 6500 switches (6506s and 6509s) to SUP32 from SUP1A and don't have physical access to them at this time. I need to verify if these switches have High Speed Fans and would like to know if there is a command I can enter to check this. If not, is a physical inspection of the fan card my only option?
Thank you.
dominic.caron Thu, 12/20/2007 - 07:45
  • Silver, 250 points or more
Hostname#sh environment status
backplane:
operating clock count: 2
operating VTT count: 3
fan-tray 1:
fan-tray 1 type: WS-C6K-9SLOT-FAN2
Rate helpful post
rsdauman13 Thu, 12/20/2007 - 08:00
Sorry, this is to replace fan trays. And, yes, this is CatOS. Using the suggestions so far, I am not able to determine anything; "sho environment" does not display the specific fan tray card.
Danilo Dy Thu, 12/20/2007 - 08:01
  • Blue, 1500 points or more
Try "show environment cooling", this command is for CATOS
Dandy
Jon Marshall Thu, 12/20/2007 - 08:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you are running native then as others have said "sh env status" or the shorter version "sh env cooling".
If you are running CatOS it is a bit harder. I can't find a command to show the fan type. You can however show the power. If you have anything less that 2500W i believe it must be one of the original fans because you need at least 2500W to power a high-speed fan.
if your'e power supplies are 2500W or greater then i can't find a way other than a physical check although i did think there was a command. I'll keep looking unless someone else can step in.
Jon
rsdauman13 Thu, 12/20/2007 - 08:34
All of the switches for which I am replacing a SUP1A to a SUP32 have 1300W power supplies. While I do plan on getting the fan card part # spot checked, would it be safe to say based on my installed power supplies that I DON'T currently have high speed fan trays?
Thanks!
Jon Marshall Thu, 12/20/2007 - 12:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes i think it's safe to say that. Also just in case you missed it you will need to upgrade your power supplies as well to a minimum of 2500W.
Jon
