MOH file location
Hi !
Maybe i didn't understood something, but i am wondering if it is possible to store the moh audio file somewhere than on the flash file system on the router ?
If yes, what are the option ? My customer want a moh file which is too big for the flash. and want to be able to modify it without accessing the router.
TFTP server ?
Broadcast the file from a server ?
Multicast ? .....
My customer want to have the moh file on his Win 2003 server.
I know i can broadcast audio from an audio feed using a FXO port.
Ill appreciate any help with this !
using 2801 w/ 2x 4FXO Cisco CME 4.2 AIM CUE 3.1.1
Overall Rating: 3 (1 ratings)
ccbootcamp Tue, 01/01/2008 - 20:51
The answer to that question is NO. You need to store it on flash. It can not be stored on a seperate device. (At least not that I am aware of) You can get a 256MB flash card for the 2801 if that will help.
(please rate the post if this helps!)
