7961 firmware for CUCM 6.0
Dec 20th, 2007
we have both the 7960 and 7961 phones. They are all in the same CM groups/dial groups etc, but the 7961's will not dial out. The 7960 dials out just fine.
Is there a new firmware version for the 7961 on CUCM 6.0, or where would I fine that?
mciarfello Sun, 12/30/2007 - 20:40
  • Silver, 250 points or more
*I*'m not aware of any firmware issues and dialing out issues for 7961.
Double check your calling search space assignment for those phones / directory number(s) on those phones.
What happens when you try to dial out?
mike@amborn.com Mon, 01/07/2008 - 14:20
I'm seeing a similar problem 7961's only, same firmware version, affected out a gateway with Version 12.4(15)T1 code.
Anyone got a solution?
