Advise for finding "top talkers" on Cisco ASA
westcare
Is there a command that will show the users that are using the most bandwidth? Or do I need a 3rd party application that monitors the pipe? I'm basically noticing a spike in bandwidth usage once in a while and have no way of easily identifying the culprit. Any suggestions would be greatly appreciated.
Jeff
Aside from the SSL features the ASDM got a big overhaul. It now includes a firewall dashboard where you can see top access rules, services, hosts etc.
acomiskey
Level 10
Level 10
You can do this through the ASDM on ASA version 8 with ASDM 6.
Great, is it pretty obvious on how this is done? I also see that Version 8 is mainly focused on SSL VPN features...
Are there any "gotcha's" with upgrading to version 8?
Thanks again for the suggestion!
