IPSEC VPN setup question
Dec 20th, 2007
I'm new to Cisco (just bought an ASA 5510 using ASDM v. 6) and am struggling setting up IPSEC VPN using a shared key. I used the setup Wizard, setup a user account, etc. I really don't know where to go from here.
When I install the VPN client, don't I need a .PCF file? How do I generate this file from ASDM? Am I on the right track?
Any advice would be appreciated!
acomiskey Thu, 12/20/2007 - 14:32
The .pcf file is generated by the vpn client application when you create a connection entry. You don't generate it from the ASDM.
