12-21-2007 12:57 AM - edited 03-15-2019 07:54 AM
hi,
i' ve CCME 4.1 configured with SIP and SCCP Phones.
i ve running Mobile Nokia E65 SIP Phones and Cisco 7961 SCCP Phones.
someone know if the SIP Phone can have the same number like the SCCP Phone. so that both phones will ring at the same time?
my config:
ephone-dn 1 dual-line
number 771
label 771
name 771
corlist incoming AllNums
ephone 1
description 771
mac-address <mac>
button 1:1
huntstop channel
voice register dn 1
number 771
name 771
voice register pool 1
id mac <MAC-NOKIA>
number 1 dn 1
cor incoming AllNums default
codec g711ulaw
thx for ur help.
~elkono
Solved! Go to Solution.
12-21-2007 03:04 AM
No, that wont' work.
First, there are two types of hunt-groups in CCME, SCCP and SIP. Each type can be composed only of member phones that are consistently SCCP or SIP.
Second, only SIP hunt-group supports broadcast type.
Instead, the only method to ring more than one phone of SCCP, is shared lines.
And if you are thinking of trying something with call forward, that won't work neither, because CFA is disabled for hunt-group members.
So for the problem in question, either get intellisyinc software to make the nokia an SCCP phone, or use call-forward no-answer to move the call from one number to another.
12-21-2007 02:43 AM
They can have the same number, but will not ring at the same time. They will ring-round robin, or if a preference is used, according to that.
It is not possible to have SIP and SCCP phones ring at the same time - this is called shared line and is supported only across consistent protocol.
12-21-2007 02:58 AM
You could if you use a hunt grp and broadcast setup though I`m not sure if broadcast is supported in CME. Create a pilot DN which is your "real" number and then assign dummy numbers to the two devices and label them with the "real" number so calls from them look correct
12-21-2007 03:04 AM
