Javardp on 5505
Dec 21st, 2007
I configured an Javardp on asa 5505.
The asa is connected behind an isa 2006 server. Now if i connect on the outside interface in the office everything works fine. If i connect via the internet to the public ip i get a connection error of the javardp, I can log into the asa5505 but not able to start the rdp session.
Is there something I need to configure on the isa for java access?
Best regards
Jorg
irisrios Fri, 12/28/2007 - 07:17
  • Silver, 250 points or more
Check the static rules and make sure that TCP port 3389 is opened for RDP session. Also check the Access list configuration and ensure that the ip address is allowed. Use the commands clear xlate , clear local ,clear arp to clear the cache and try again.
jorg.ramakers Wed, 01/30/2008 - 01:05
I solved it. My javaRDP pugin on the asa was corrupted. I uploaded the new image and it works.
Jorg
